[Geoserver-devel] [jira] (GEOS-5033) Configuration problems with Integrated GeoWebCache
Simone Giannecchini created GEOS-5033:
             Summary: Configuration problems with Integrated GeoWebCache
                 Key: GEOS-5033
                 URL: https://jira.codehaus.org/browse/GEOS-5033
             Project: GeoServer
          Issue Type: Bug
          Components: GWC
    Affects Versions: 2.2.x
            Reporter: Simone Giannecchini
            Assignee: Andrea Aime
If I go to the GeoWebCache Settings and deselect all the options for :
- GWC Provided Services
- Default Caching Options for GeoServer Layers
- Disk Quota
I press submit, I stop the GeoServer then I restart, all the checkboxes are checked again.
I don't believe this is normal.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
