[Geoserver-devel] [jira] (GEOS-5035) Latent bounding box exception for WMS with small extent
K. Arthur Endsley created GEOS-5035:
             Summary: Latent bounding box exception for WMS with small extent
                 Key: GEOS-5035
                 URL: https://jira.codehaus.org/browse/GEOS-5035
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.1
         Environment: Sun Microsystems Inc.: 1.6.0_24 (Java HotSpot(TM) Client VM);
Build Information:
    Version 2.1.1
    Subversion Revision 16080
    Build Date 23-Jun-2011 10:45
    GeoTools Version 2.7.2 (rev 37473)
            Reporter: K. Arthur Endsley
            Assignee: Andrea Aime
I've set up GeoServer WMS stores for several small areas (~4,000 to 5,000 ft^2) from GeoTIFFs in GCS WGS84. Initially, the precision displayed in the Layer description, under the Data tab beneath "Coordinate Reference Systems," is inadequate (limited to three decimal places). When I set up the Layer(s) the first time, I left this alone. However, when attempting to preview the Layer(s), I received the following ServiceException:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://vm-winserv08-a.mtri.org:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt; <ServiceExceptionReport version="1.1.1" > <ServiceException code="InvalidBBox">
      The request bounding box has zero area: ReferencedEnvelope[-84.778 : -84.777, 43.956 : 43.956]
</ServiceException></ServiceExceptionReport>
I fixed this by going back in Layer description and typing in higher-precision bounds. By "fixed" I mean that the WMS worked afterwards. However, I've found that after a couple days or so I get the ServiceException again, though I've changed nothing about the Layer description. If I did change the Layer description in some way (e.g. change the selected Style), I always manually entered the high-precision bounds again and tested the WMS to see that it worked.
Here is an example WMS stream that is affected which, note, may be working because I am still "fixing" these Layers as the problem arises (obviously, I'd like to not have to re-enter bounding box coordinates every few days):
http://vm-winserv08-a.mtri.org:8080/geoserver/BridgeConditionDSS/wms?service=WMS&version=1.1.0&request=GetMap&layers=BridgeConditionDSS:MannsidingDEM_EastBridge_WGS84&styles=&bbox=-84.7764333996,43.9562142521,-84.7758066003,43.9564145468&width=1032&height=330&srs=EPSG:4326&format=application/openlayers
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
