Gabriel Roldán created GEOS-5039:
Summary: Rearrange GWC UI components for higher consistency
Key: GEOS-5039
URL: https://jira.codehaus.org/browse/GEOS-5039
Project: GeoServer
Issue Type: Improvement
Components: GWC, Wicket UI
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 2.2.x
Rearrange the GWC UI components so that the GWC/Tiling UI is more self contained and less spread all over the place.
For instance:
- Make the LayerGroup tile cache config be on a tab inside the layer group edit page, just like it is in the layer edit page.
- Create a separate top level menu entry
* call it "Tile Cache" instead of GeoWebcache
* move the "cached layers page" as a submenu
* create sub menu entries for global config, gridsets
Check [this email thread|http://osgeo-org.1560.n6.nabble.com/asking-for-feedback-on-gwc-integration-improvements-td4335885.html\] for more background information.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
