[Geoserver-devel] [jira] (GEOS-5044) GeoTIFF with infile SRS causes an error
Alexander Oros created GEOS-5044:
             Summary: GeoTIFF with infile SRS causes an error
                 Key: GEOS-5044
                 URL: https://jira.codehaus.org/browse/GEOS-5044
             Project: GeoServer
          Issue Type: Bug
          Components: Validation
    Affects Versions: 2.1.3
            Reporter: Alexander Oros
            Assignee: Andrea Aime
            Priority: Minor
when I try to create a Layer from an GeoTiff with the following srs information the Server responds with an error screen that is not very constructiv.
PROJCS["Lambert Conformal Conic; WGS84; WGS84", GEOGCS["unnamed", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH]], PROJECTION["Lambert_Conformal_Conic_2SP"], PARAMETER["central_meridian", 10.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["standard_parallel_1", 54.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["standard_parallel_2", 50.0], UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH]]
java.lang.IllegalArgumentException: null incompatible with DEFAULT_COORDINATE_REFERENCE_SYSTEM
  at java.awt.RenderingHints.put(RenderingHints.java:1057)
  at org.geotools.factory.Hints.<init>(Hints.java:963)
  at org.geoserver.catalog.impl.CoverageInfoImpl.getGridCoverageReader(CoverageInfoImpl.java:156)
  at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:576)
  at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:528)
  at org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:115)
  at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
  at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
  at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
  at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
  at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
  at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
  at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1542)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:343)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:217)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
  at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
  at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
  at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
  at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
  at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
  at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
  at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
  at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
  at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:279)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
  at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
  at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:161)
  at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:331)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:231)
  at com.sun.enterprise.v3.services.impl.ContainerMapper$AdapterCallable.call(ContainerMapper.java:317)
  at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:195)
  at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:849)
  at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:746)
  at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1045)
  at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:228)
  at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
  at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
  at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
  at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
  at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
  at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
  at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
  at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
  at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
  at java.lang.Thread.run(Thread.java:662)
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
