Michael Newcomb created GEOS-5046:
Summary: Can't create ShapeFIle layer
Key: GEOS-5046
URL: https://jira.codehaus.org/browse/GEOS-5046
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1.3
Environment: Tomcat 7.0.26
GeoServer 2.1.3
Reporter: Michael Newcomb
Assignee: Andrea Aime
Default configuration of Tomcat.
Default configuration of GeoServer 2.1.3.
Create a new store to one of the test shape files shipped with GeoServer. Tried to create a layer and everytime you hit 'save' it just stays on the page and when you go back to the layers list, it is not there. No exception or anything.
The exact same procedure works fine in GeoServer 2.1.2 and Tomcat.
As a side note, the layers that are preconfigured all work just fine, it only happens when you try to reconfigure. So, to reproduce, delete one of the 'shipped-with' layers and try to re-add it.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
