[Geoserver-devel] [jira] (GEOS-5049) GeoServer Rest API fails on sld with OnlineResource and a dynamic symbolizer
Ivan Willig created GEOS-5049:
             Summary: GeoServer Rest API fails on sld with OnlineResource and a dynamic symbolizer
                 Key: GEOS-5049
                 URL: https://jira.codehaus.org/browse/GEOS-5049
             Project: GeoServer
          Issue Type: Bug
          Components: REST
         Environment: Fedora, Sun Java JDK 1.6,
            Reporter: Ivan Willig
            Assignee: Justin Deoliveira
         Attachments: irene_points.sld
When I attempt to upload an sld style via the rest API GeoServer raises a stack trace. When I try to upload the same style file via the Wicket UI GeoServer handles the style correctly. Once I get the style into GeoServer everything works correctly. This leads me to believe that this is an error in the Rest API's parsing of the SLD document.
Attached is the style that causes this error.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
