Martin Davis created GEOS-5051:
Summary: Predefined Env variables should reflect actual image size when metatiling is used
Key: GEOS-5051
URL: https://jira.codehaus.org/browse/GEOS-5051
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.2-beta1
Reporter: Martin Davis
Assignee: Andrea Aime
Currently the predefined Env variables wms_width and wms_height provide the size of the requested image. When metatiling is being used, the rendering system is actually generating an image which is larger than the requested size. This inconsistency causes problems with some kinds of rendering transformations (in particular, ones whose behaviour is sensitive to the output image size).
The current code is at line 450 in GetMap.java. The fix is presumably to set these variables to be the actual metatile size. Or, if it is actually useful to be able to determine the output image size, should there be two new variables which provide the rendered image size?
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
