[Geoserver-devel] [jira] (GEOS-5055) REST API writes invalid layergroup configuration to disk when layergroup references non-existent layer
David Winslow created GEOS-5055:
             Summary: REST API writes invalid layergroup configuration to disk when layergroup references non-existent layer
                 Key: GEOS-5055
                 URL: https://jira.codehaus.org/browse/GEOS-5055
             Project: GeoServer
          Issue Type: Bug
          Components: REST
            Reporter: David Winslow
            Assignee: Andrea Aime
In the REST API, modifying a layergroup to include a reference to a layer name that's not associated with any layer in GeoServer will cause an invalid layergroup to be persisted to the catalog. The in-memory catalog doesn't retain it, leading to a curious case where attempts to update or delete the layergroup (to correct the issue) fail with a "404 Not Found" error and attempts to create a new layergroup in its place fail with a "403 Name already in use" error.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
