[Geoserver-devel] [jira] (GEOS-5057) Name conflict resolution for new layers in REST API
David Winslow created GEOS-5057:
             Summary: Name conflict resolution for new layers in REST API
                 Key: GEOS-5057
                 URL: https://jira.codehaus.org/browse/GEOS-5057
             Project: GeoServer
          Issue Type: Bug
          Components: REST
            Reporter: David Winslow
            Assignee: Justin Deoliveira
The setup for this one is a little complicated:
1) Start from default "release" dataset
2) Add a shapefile named "roads" in the {{topp:}} namespace
3) Add a postgis datastore in the same namespace.
4) Repeatedly upload the roads shapefile to the postgis datastore.
This creates a table named "roads" in the database, but since the layer name "roads" is already taken we munge the name with a numeric suffix. However, instead of simply appending data to the existing layer, subsequent uploads add data to the same table, but create new layers with increasing numeric suffixes (up to a max of 9 in my testing; after that layer creation fails.)
Another odd bit I found during my testing was that the last upload only fails *after* importing the data into the table, so we end up with more copies of the data than we "successfully" imported.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
