[Geoserver-devel] [jira] (GEOS-5058) Creating PostGIS tables via REST API doesn't validate that created table has valid Postgres table name
David Winslow created GEOS-5058:
             Summary: Creating PostGIS tables via REST API doesn't validate that created table has valid Postgres table name
                 Key: GEOS-5058
                 URL: https://jira.codehaus.org/browse/GEOS-5058
             Project: GeoServer
          Issue Type: Bug
          Components: REST
            Reporter: David Winslow
            Assignee: Justin Deoliveira
If you upload a Shapefile with a very long filename (exceeding the identifier length limit for Postgres which defaults to 63) then GeoServer will issue a SQL command to CREATE TABLE with an invalid identifier. By spec, Postgres ignores the remainder of the identifier, so the created table will not have the expected name. GeoServer then fails the rest of the layer configuration due to the expected table name not being found (and the table remains in the database anyway.)
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
