[Geoserver-devel] [jira] (GEOS-5063) Support Informix as a JDBC authentication provider
Torsten Heinen created GEOS-5063:
             Summary: Support Informix as a JDBC authentication provider
                 Key: GEOS-5063
                 URL: https://jira.codehaus.org/browse/GEOS-5063
             Project: GeoServer
          Issue Type: Improvement
          Components: Security
    Affects Versions: 2.2-beta1
            Reporter: Torsten Heinen
            Assignee: Andrea Aime
            Priority: Minor
Informix cannot be used as a JDBC authentication provider [1]. It seems that the Informix JDBC driver does not support the discovery through the "DriverManager.getDrivers" method that is used in the new security subsystem to find all available JDBC drivers.
Looking at the Informix docs, it seems that the driver needs to be discovered through Class.forName [2] and instantiated with DriverManager.getConnection(url) [3].
[1] http://thread.gmane.org/gmane.comp.gis.geoserver.user/32105
[2] http://publib.boulder.ibm.com/infocenter/idshelp/v10/index.jsp?topic=/com.ibm.jdbc_pg.doc/jdbc51.htm
[3] http://publib.boulder.ibm.com/infocenter/idshelp/v10/index.jsp?topic=/com.ibm.jdbc_pg.doc/jdbc48.htm
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
