[Geoserver-devel] [jira] (GEOS-5065) Move cas out to separate security module
Justin Deoliveira created GEOS-5065:
             Summary: Move cas out to separate security module
                 Key: GEOS-5065
                 URL: https://jira.codehaus.org/browse/GEOS-5065
             Project: GeoServer
          Issue Type: Task
          Components: Security
    Affects Versions: 2.2-beta1
            Reporter: Justin Deoliveira
            Assignee: Justin Deoliveira
             Fix For: 2.2.x
Similar to ldap and jdbc, cas probably deserves its own module, main issue is the security filter configuration, we should be able to fix that with an additional callback function to GEoServerSecurityProvider
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
