[Geoserver-devel] [jira] (GEOS-5069) Rest default workspace throws 404 using curl without credentials
Michael Romero created GEOS-5069:
             Summary: Rest default workspace throws 404 using curl without credentials
                 Key: GEOS-5069
                 URL: https://jira.codehaus.org/browse/GEOS-5069
             Project: GeoServer
          Issue Type: Bug
          Components: REST, Security
    Affects Versions: 2.2-beta1
         Environment: Ubuntu 11.10 x64
Java 1.6.0_29
curl 7.21.6
Firefox 11.0
            Reporter: Michael Romero
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 2.2-beta1
I configured anonymous GET my rest.propertes and requested the default workspace from Firefox (http://localhost:8080/geoserver/rest/workspaces/default.xml) which worked fine. I also tried a few workspaces that come out of the box (e.g. topp). Then I tried the same url using curl:
curl -k "http://localhost:8080/geoserver/rest/workspaces/default.xml"
I got a message back "No such workspace: default" and using wget showed I was getting a 404 response code. If I add the credentials to the curl request it works fine.
curl -k -u $user:$pass "http://localhost:8080/geoservspaces/default.xml"
I tried this in JBoss 5.1 GA and in the standalone Jetty version of the GeoServer-2.2-beta1.
The stack trace in the Jetty version looks like this:
23 Apr 15:19:43 ERROR [geoserver.rest] - No such workspace: default
org.geoserver.rest.RestletException
  at org.geoserver.catalog.rest.WorkspaceFinder.findTarget(WorkspaceFinder.java:33)
  at org.restlet.Finder.handle(Finder.java:268)
  at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
  at org.restlet.Filter.doHandle(Filter.java:105)
  at org.restlet.Filter.handle(Filter.java:134)
  at org.restlet.Router.handle(Router.java:444)
  at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
  at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
  at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
  at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
  at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
  at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
  at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
  at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
  at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:99)
  at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
  at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
  at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
  at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
