[Geoserver-devel] [jira] (GEOS-5073) org.geoserver.catalog.impl.ProxyList is said to be immutable, but it's not
Gabriel Roldán created GEOS-5073:
             Summary: org.geoserver.catalog.impl.ProxyList is said to be immutable, but it's not
                 Key: GEOS-5073
                 URL: https://jira.codehaus.org/browse/GEOS-5073
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.2-beta1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.2-beta2
The following patch is all what's needed for the default Catalog to truly return immutable lists. All tests still pass except the one patched, which was asserting the immutable list was mutable.
{code}
--- a/src/main/src/main/java/org/geoserver/catalog/impl/ProxyList.java
+++ b/src/main/src/main/java/org/geoserver/catalog/impl/ProxyList.java
@@ -4,7 +4,6 @@
package org.geoserver.catalog.impl;
-import java.lang.reflect.Proxy;
import java.util.AbstractList;
import java.util.List;
@@ -35,12 +34,8 @@ public abstract class ProxyList extends AbstractList {
     @Override
     public Object set(int index, Object element) {
- if ( !proxyInterface.isInstance( element ) || !(element instanceof Proxy) ) {
             throw new IllegalArgumentException(
                 "Object is not a proxy, or not a proxy of the correct type");
- return proxyList.set(index, unwrapProxy(element, proxyInterface));
     public int size() {
diff --git a/src/main/src/test/java/org/geoserver/catalog/impl/CatalogImplTest.java b/src/main/src/test/java/org/geoserver/catalog/impl/CatalogImplTest.java
index 6bee7b8..7a2410a 100644
--- a/src/main/src/test/java/org/geoserver/catalog/impl/CatalogImplTest.java
+++ b/src/main/src/test/java/org/geoserver/catalog/impl/CatalogImplTest.java
@@ -1386,16 +1386,22 @@ public class CatalogImplTest extends TestCase {
         List<StyleInfo> styles = catalog.getStyles();
         assertEquals( 2 , styles.size() );
- assertEquals( s.getName(), styles.get( 0 ).getName() );
- assertEquals( "a"+s.getName(), styles.get( 1).getName() );
- //test sorting
- Collections.sort( styles, new Comparator<StyleInfo>() {
+ //test immutability
+ Comparator<StyleInfo> comparator = new Comparator<StyleInfo>() {
             public int compare(StyleInfo o1, StyleInfo o2) {
                 return o1.getName().compareTo( o2.getName());
+ try {
+ Collections.sort(styles, comparator);
+ fail("Expected runtime exception, immutable collection");
+ } catch (RuntimeException e) {
+ assertTrue(true);
+ styles = new ArrayList<StyleInfo>(styles);
         assertEquals( "a"+s.getName(), styles.get( 0 ).getName() );
         assertEquals( s.getName(), styles.get( 1 ).getName() );
{code}
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
