[Geoserver-devel] [jira] (GEOS-5077) Geometry tables with srid = 0 are not ignored and treated as unknown
Gregory Giuliani created GEOS-5077:
             Summary: Geometry tables with srid = 0 are not ignored and treated as unknown
                 Key: GEOS-5077
                 URL: https://jira.codehaus.org/browse/GEOS-5077
             Project: GeoServer
          Issue Type: Bug
          Components: SQLServer
    Affects Versions: 2.1.3
         Environment: Linux Debian 6.0.4
OpenGeo 2.6.5
GeoServer 2.1-SNAPSHOT
SQLServer 2.1-SNAPSHOT (26.04.2012)
            Reporter: Gregory Giuliani
            Assignee: Andrea Aime
Geometry tables with srid = 0.
It sounds like a bug in the sql server driver since it should just ignore this and treat zero as unknown.
This impends to calculate bounds while publishing data stored in MS SQL server.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
