[Geoserver-devel] [jira] (GEOS-5085) WFS 2.0 paging returns wrong features for startindex=0
Ben Caradoc-Davies created GEOS-5085:
             Summary: WFS 2.0 paging returns wrong features for startindex=0
                 Key: GEOS-5085
                 URL: https://jira.codehaus.org/browse/GEOS-5085
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 2.2.x
         Environment: postgresql-9.1_9.1.3-2_i386.deb
GeoServer:
Version 2.2-SNAPSHOT
Subversion Revision 16812
Build Date 11-Mar-2012 19:23
GeoTools Version 8-SNAPSHOT (rev 38626)
            Reporter: Ben Caradoc-Davies
            Assignee: Justin Deoliveira
            Priority: Critical
Looks like WFS 2.0 startindex=0 does not trigger the sorting used to implement paging, causing the first page of results to be inconsistent with subsequent pages, resulting in duplicate features in the data set.
I have some simple features (numberMatched="1354965") from a source postgis table with an integer primary key starting at 1. If I ask for the first page (startindex=0), I get some random features. If I ask for subsequent pages, they appear as if the first count were the features with primary key 1..count.
For example, if I set count=1:
count=1&startindex=0
Response has: gml:id="lith_samples.808129"
count=1&startindex=1
Response has: gml:id="lith_samples.2"
count=1&startindex=2
Response has: gml:id="lith_samples.3"
and
count=1&startindex=808128
Response has: gml:id=""lith_samples.808129"
Duplicate feature!
I suspect that there is a logic error for startindex=0. How does the implementation distinguish between startindex=0 and no startindex supplied?
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
