[Geoserver-devel] [jira] (GEOS-5097) When using TIME or ELEVATION parameter filter on a GWC tile layer cache the current value
Gabriel Roldán created GEOS-5097:
             Summary: When using TIME or ELEVATION parameter filter on a GWC tile layer cache the current value
                 Key: GEOS-5097
                 URL: https://jira.codehaus.org/browse/GEOS-5097
             Project: GeoServer
          Issue Type: Improvement
          Components: GWC
    Affects Versions: 2.2-beta2
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.2.x
See GEOS-5003 for reference.
If a layer has time or elevation enabled, and a tile request comes asking for the default (current) value, that value might change over time.
If GWC uses the default cache tiles would be generated at different times, possibly with different "current" values.
Make it so that GWC automatically sets the appropriate parameter filter value to the explicit "current" value for the required dimension.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
