David Winslow created GEOS-5109:
Summary: Do "already configured?" check based on native name, not published one
Key: GEOS-5109
URL: https://jira.codehaus.org/browse/GEOS-5109
Project: GeoServer
Issue Type: Bug
Components: REST
Affects Versions: 2.1.3
Reporter: David Winslow
Assignee: Justin Deoliveira
Fix For: 2.1.4
The upload handler in the REST API uses published names instead of native ones when deciding whether layers are already configured in the catalog. When replacing or appending to an existing store this means the layer gets "re-published" unnecessarily, eventually leading to name exhaustion.
Patch on Github at https://github.com/dwins/geoserver/commit/ea04b1bc279bde403517ecb27a0f4f81b1b48361 (or https://github.com/dwins/geoserver/commit/ea04b1bc279bde403517ecb27a0f4f81b1b48361\.diff for the actual patch file.)
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
