[Geoserver-devel] [jira] (GEOS-5110) Allow KML Document Title to be set by format_options parameters
Alessio Fabiani created GEOS-5110:
             Summary: Allow KML Document Title to be set by format_options parameters
                 Key: GEOS-5110
                 URL: https://jira.codehaus.org/browse/GEOS-5110
             Project: GeoServer
          Issue Type: Improvement
          Components: Google Earth KML Output
            Reporter: Alessio Fabiani
            Assignee: Alessio Fabiani
         Attachments: kml_title_formatOption.patch
It would be very nice to have the possibility of forcing the Title of the output KML document through a format_options parameter.
Something like
format_options=kmltitle:myCustomLayerTitle
The attached patch, improves the GeoServer KML output in order to take into account the provided parameter.
There are also a lot of tests covering almost all cases.
NOTE: The KMLSuperOverlayTransformerTest is formatted from scratch in any case, most probably due to a CR/LF difference between Windows and Linux.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
Alessio Fabiani reopened ImprovementGEOS-5110
Change By:
Alessio Fabiani (23/May/12 2:56 AM)
Status:
Closed Reopened
Resolution:
Fixed
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
