[Geoserver-devel] [jira] (GEOS-5138) bug in the automatic size calculation of the legend
D. Stroeer created BugGEOS-5138
Issue Type:
BugBug
Assignee:
Andrea Aime
Created:
31/May/12 9:26 AM
Description:
I set up some Web Map Services with the Geoserver and visualize
everything with OpenLayers. For some Services I added legends and those
are working, but the “Title”, which appears above the legend graphic of
those services gets cut. In some cases one letter is absent, in other
cases two. So I tried to change the size of the legend graphic, but it
only works with the value “auto” for the size
Project:
Priority:
MinorMinor
Reporter:
D. Stroeer
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
