Issue Type:
Bug
Affects Versions:
2.1.3
Assignee:
Andrea Aime
Created:
04/Jun/12 7:00 AM
Description:
We are having problems to generate pdf files which polygons are filled with external images.
Our layers are loaded from an oracle database, the image puntos_desordenados.png is in folder /styles inside the data directory and sld code is (full sld file is attached):
<sld:Rule>
<sld:Name>RED_LOCAL</sld:Name>
<sld:Title>Red local</sld:Title>
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>DS_TIPO</ogc:PropertyName>
<ogc:Literal>RED_LOCAL</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
<sld:PolygonSymbolizer>
<sld:Fill>
<sld:GraphicFill>
<sld:Graphic>
<sld:ExternalGraphic>
<sld:OnlineResource
xlink:type=“simple”
xlink:href=“puntos_desordenados.png”/>
<sld:Format>image/png</sld:Format>
</sld:ExternalGraphic>
<sld:Size>16</sld:Size>
</sld:Graphic>
</sld:GraphicFill>
</sld:Fill>
<sld:Stroke>
<sld:CssParameter name=“stroke”>#3F3F3F</sld:CssParameter>
<sld:CssParameter name=“stroke-width”>0.8</sld:CssParameter>
</sld:Stroke>
</sld:PolygonSymbolizer>
</sld:Rule>
These are some examples of urls generated by geoserver:
WMS/png:
http://desarrollo.madrid.org/geoserver/wms?LAYERS=Madrid%3AVPLA_REDES&STYLES=&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23030&BBOX=470958.60996777,4487001.4935801,473934.50446777,4489820.4561435&WIDTH=512&HEIGHT=485
WMS/pdf:
desarrollo.madrid.org/geoserver/wms?LAYERS=Madrid%3AVPLA_REDES&STYLES=&FORMAT=application%2Fpdf&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23030&BBOX=470958.60996777,4487001.4935801,473934.50446777,4489820.4561435&WIDTH=512&HEIGHT=485
downloading Madrid_VPLA_REDES.pdf
As you can see, the pdf request doesn’t fill areas with external image as png request does. The problem still appears if we change the image ‘puntos_desordenados.png’ for other one (in format png, jpg or gif)
We don’t have this problem in point layers with external images neither in polygon layers with geoserver native styles. In these cases the pdf output is right.
Project:
Priority:
Major
Reporter:
RUBEN ILLANA
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
