[Geoserver-devel] [jira] (GEOS-5146) RPFTOC reader cannot load RPF .TOC files
Zach Toups created BugGEOS-5146
Issue Type:
BugBug
Affects Versions:
2.2-beta2
Assignee:
Andrea Aime
Created:
05/Jun/12 3:30 PM
Description:
Using the imageio-ext-gdal add-on. Attempting to add an RPF layer to GeoServer using the RPFTOC store type. When the path to the RPF.TOC file is provided, the error below occurs (and GeoServer reports “Could not list layers for this store, an error occurred retrieving them: null”). I get the error with the path to the /rpf folder and the A.TOC file itself, which is the same error as any other location. Have tried multiple RPF datasets that are known to work on our OpenMap server.
2012-06-05 14:46:40,671 INFO [geoserver.web] - Getting list of coverages for saved store file://<path.to.A.toc>
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: null
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:123)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:56)
at org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:226)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:532)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.<init>(GeoServerTablePanel.java:525)
at org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:200)
at org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:91)
at org.geoserver.web.data.layer.NewLayerPage$1.<init>(NewLayerPage.java:100)
at org.geoserver.web.data.layer.NewLayerPage.<init>(NewLayerPage.java:100)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:71)
Environment:
Windows 7x64, Tomcat 7.0
Project:
Priority:
MajorMajor
Reporter:
Zach Toups
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
