[Geoserver-devel] [jira] (GEOS-5167) Metadata URL in WMS 1.3.0 capabilities is wrong host is localhost
Michael Romero created BugGEOS-5167
Issue Type:
BugBug
Affects Versions:
2.2.x
Assignee:
Andrea Aime
metadataUrlPatch.diff
Components:
WMS
Created:
13/Jun/12 5:24 PM
Description:
There are two issues with the URL in the capabilities document if localhost is in the metadata URL for a layer. (1) The KVP query is chopped off and (2) if the URL path points somewhere different than the path of the Proxy Base URL then the URL is wrong. I attached a patch that addresses both issues.
Here is an example:
Proxy Base URL:
https://example.com/geoserver
Metadata URL (layer):
http://localhost:8080/metdata?key1=value1&key2=value2
Metadata URL (capabilities):
https://example.com/geoserver/metadata
Should Be:
https://example.com/metadata?key1=value1&key2=value2
Project:
Priority:
MinorMinor
Reporter:
Michael Romero
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
Justin Deoliveira reopened BugGEOS-5167
Change By:
Justin Deoliveira (12/Jul/12 9:07 AM)
Status:
Resolved Reopened
Resolution:
Fixed
