[Geoserver-devel] [jira] (GEOS-5173) SLDs with Rendering Transformations do not validate in Style Editor
Martin Davis created BugGEOS-5173
Issue Type:
BugBug
Affects Versions:
2.2-beta2
Assignee:
Martin Davis
rendering_trans_sld_xsd.patch
Components:
WMS
Created:
15/Jun/12 6:01 PM
Description:
SLDs containing Rendering Transformations do not validate in the Style Editor,
because the new <Transformation> element is not defined in the XSD.
Fixed by adding the element with minimal syntax.
It is possible to tighten up the validation even more by adding more syntax to the Transformation element. Ie. check that the function arguments are all functions with a string (process parameter name) as the first argument.
Fix Versions:
2.2.x
Project:
Priority:
MinorMinor
Reporter:
Martin Davis
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
