[Geoserver-devel] [jira] (GEOS-5179) Geoserver 2.14 war doesn't respond in JBoss AS7.1 in OpenShift
Marc Pfister created BugGEOS-5179
Geoserver 2.14 war doesn’t respond in JBoss AS7.1 in OpenShift
Issue Type:
BugBug
Affects Versions:
2.1.4
Assignee:
Andrea Aime
Created:
19/Jun/12 5:57 PM
Description:
Deploying GeoServer 2.1.3 on OpenShift with the JBoss AS7.1 cartridge works fine following these directions: http://dubrovsky.posterous.com/geoserver-on-openshift. Trying the same process with 2.1.4 results in empty responses from the server, even with invalid URLs that would normally 404.
Environment:
OpenShift
Project:
Priority:
MajorMajor
Reporter:
Marc Pfister
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
