Issue Type:
Bug
Affects Versions:
2.2-beta2
Assignee:
Andrea Aime
Components:
WMS
Created:
19/Jun/12 6:16 PM
Description:
If a layer is styled with a Rendering Transformation that changes the schema of the layer, GetFeatureInfo can fail. This is because the underlying layer featuretype is queried using the style rules as filters, and if they refer to the attributes in the modified schema the filter evaluation will fail.
The problem occurs in GetFeatureInfo.java in execute(GetFeatureInfoRequest request, Style styles, Filter filters) where identifyVectorLayer() is called to create a query feature collection using the style filters.
Stack trace from a setup causing the issue is:
Caused by: java.lang.NullPointerException
at org.geotools.filter.IsBetweenImpl.evaluateInternal(IsBetweenImpl.java:114)
at org.geotools.filter.IsBetweenImpl.evaluate(IsBetweenImpl.java:74)
at org.geotools.filter.OrImpl.evaluate(OrImpl.java:44)
at org.geotools.filter.AndImpl.evaluate(AndImpl.java:57)
at org.geotools.data.FilteringFeatureReader.hasNext(FilteringFeatureReader.java:130)
at org.geotools.data.ReTypeFeatureReader.hasNext(ReTypeFeatureReader.java:194)
at org.geotools.data.MaxFeatureReader.hasNext(MaxFeatureReader.java:86)
at org.geotools.data.DefaultFeatureResults.getCount(DefaultFeatureResults.java:334)
at org.geotools.data.store.DataFeatureCollection.size(DataFeatureCollection.java:271)
at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.size(ForceCoordinateSystemFeatureResults.java:106)
at org.geoserver.wms.GetFeatureInfo.execute(GetFeatureInfo.java:301)
at org.geoserver.wms.GetFeatureInfo.execute(GetFeatureInfo.java:172)
The fix might be to check if a style contains a rendering transformation and if so avoid querying the layer.
Project:
Priority:
Major
Reporter:
Martin Davis
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
