[Geoserver-devel] [jira] (GEOS-5203) Build failing from trunk
Joao Duarte created BugGEOS-5203
Issue Type:
BugBug
Assignee:
Andrea Aime
Created:
03/Jul/12 4:19 AM
Description:
Building from trunk is failing. Some test is nos passing on the main module. Here’s the build report:
Results :
Failed tests: testIsModified(org.geoserver.security.xml.XMLUserGroupServiceTest)
testEmptyPassword(org.geoserver.security.xml.XMLUserGroupServiceTest): expected:<0> but was:<6>
Tests in error:
testEraseCredentials(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked
testPasswordRecoding(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked
testGlobal(org.geoserver.template.GeoServerTemplateLoader2Test): org.geoserver.data.test.LiveData cannot be cast
to org.geoserver.data.test.MockData
Tests run: 460, Failures: 2, Errors: 3, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer … SUCCESS [56.175s]
[INFO] Core Platform Module … SUCCESS [11.531s]
[INFO] Open Web Service Module … SUCCESS [16.174s]
[INFO] Main Module … FAILURE [3:49.476s]
Environment:
Windows
Project:
Priority:
MajorMajor
Reporter:
Joao Duarte
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
