[Geoserver-devel] [jira] (GEOS-5206) Problem, to connect ArcDSE 10 with GEOSERVER
BERGAMASCO created ImprovementGEOS-5206
Issue Type:
ImprovementImprovement
Affects Versions:
2.1.4
Assignee:
Andrea Aime
Components:
ArcSDE
Created:
04/Jul/12 8:55 AM
Description:
Good Morning everyone,
I would like to have an inquiry, I’m trying to connect me to ArcSDE 10, in the mode “Direct Connect” with Geoserver, but Geoserver is crashing…
I put all libraries : two from ESRI = jsde_sdk.jar , jpe_sdk.jar
and the others from the extension ArcSDE
I changed the environment of my computer.
And nothing changed, i have always the same problem, but no error message, also in the debug version…
Could you help me…
Could you explain me which version of Geoserver, and which libraries do we need, to connect with ArcSDE10?
Thank you very much.
Bfloo
Environment:
Windows
Fix Versions:
2.1.4
Project:
Priority:
MajorMajor
Reporter:
BERGAMASCO
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
