[Geoserver-devel] [jira] (GEOS-5211) Duplicate processes are defined in WPS
Martin Davis created BugGEOS-5211
Issue Type:
BugBug
Affects Versions:
2.2-RC1
Assignee:
Andrea Aime
process-appcontext.patch
Components:
WPS
Created:
05/Jul/12 11:41 AM
Description:
This is because some processes are defined in both the GS wps-core applicationContext.xml, and in a GeoTools factory.
Fix is to delete them from the GS appContext.
Might also be good to add a unique filter to the process registry, to avoid this recurring.
Fix Versions:
2.2-RC2
Project:
Priority:
MinorMinor
Reporter:
Martin Davis
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
