[Geoserver-devel] [jira] (GEOS-5226) The coverage settings are getting re-initialized at each and every catalog modification
Andrea Aime created BugGEOS-5226
Issue Type:
BugBug
Affects Versions:
2.1.4
Assignee:
Daniele Romagnoli
Components:
Configuration
Created:
17/Jul/12 4:03 AM
Description:
See the following trace:
at java.util.concurrent.ThreadPoolExecutor.setMaximumPoolSize(ThreadPoolExecutor.java:1450)
at org.geoserver.coverage.CoverageAccessInitializer.initCoverage(CoverageAccessInitializer.java:94)
at org.geoserver.coverage.CoverageAccessInitializer$1.handleGlobalChange(CoverageAccessInitializer.java:51)
at org.geoserver.config.impl.GeoServerImpl.fireGlobalModified(GeoServerImpl.java:168)
at org.geoserver.config.impl.DefaultGeoServerFacade.save(DefaultGeoServerFacade.java:60)
at org.geoserver.config.impl.GeoServerImpl.save(GeoServerImpl.java:139)
at org.geoserver.config.UpdateSequenceListener.incrementSequence(UpdateSequenceListener.java:40)
at org.geoserver.config.UpdateSequenceListener.handlePostModifyEvent(UpdateSequenceListener.java:59)
at org.geoserver.catalog.impl.CatalogImpl.event(CatalogImpl.java:1192)
at org.geoserver.catalog.impl.CatalogImpl.firePostModified(CatalogImpl.java:1169)
at org.geoserver.catalog.impl.DefaultCatalogFacade.saved(DefaultCatalogFacade.java:834)
at org.geoserver.catalog.impl.DefaultCatalogFacade.save(DefaultCatalogFacade.java:771)
at org.geoserver.catalog.impl.CatalogImpl.save(CatalogImpl.java:1092)
The event handling code does not check what properties were modified, as a result the update sequence increment update happening at every change in the configuration results in a reload of the coverage settingsā€¦
Fix Versions:
2.1.5
Project:
Priority:
MajorMajor
Reporter:
Andrea Aime
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
