[Geoserver-devel] [jira] (GEOS-5232) geoserver stratindex problem bug???
pavlos tsagkis created BugGEOS-5232
Issue Type:
BugBug
Affects Versions:
2.1.4
Assignee:
Andrea Aime
Components:
Oracle
Created:
20/Jul/12 6:00 AM
Description:
I have just installed the version 2.1.4 and I am facing the following problem.
In a wfs request using the startIndex and maxFeatures parameters I get back strange behavior.
if startIndex=1 or startIndex=0 –> geoserver hungs without any error in log. just keep waiting but I never get back the response. (I suspect if I wait a bit more I should get a time out error - but I am not that patient)
If I do not specify startIndex parameter but just the maxFeatures then I get back the responce having random results, which doesnt help as every page should have different results.
If I use startIndex >1 e.g 2,3 everything works as expected. So the problem is always with the first page.
I am not sure whether this is a bug or just a new feature of the latest stable version that I am not using in the proper way.
In version 2.1.3 everything worked as expected.
I am using oracle spatial data and Oracle extension for geoserver.
My geoserver.war is deployed in Oracle weblogic Server in a cluster environment. (I havealso tested with stand-alone and still have the same problem)
The wfs requests–>
  1. http://172.31.129.149:8080/geoserver/wfs?REQUEST=getFeature&SERVICE=WFS&TYPENAME=wsp:layer&BBOX=351054.18248792,4224937.2299422,354540.18060548,4225830.4294599&PROPERTYNAME=(GEOM)&srsName=EPSG:2100&maxFeatures=50&startIndex=0
    2)http://172.31.129.149:8080/geoserver/wfs?REQUEST=getFeature&SERVICE=WFS&TYPENAME=wsp:layer&BBOX=351054.18248792,4224937.2299422,354540.18060548,4225830.4294599&PROPERTYNAME=(GEOM)&srsName=EPSG:2100&maxFeatures=51&startIndex=1
    3)http://172.31.129.149:8080/geoserver/wfs?REQUEST=getFeature&SERVICE=WFS&TYPENAME=wsp:layer&BBOX=351054.18248792,4224937.2299422,354540.18060548,4225830.4294599&PROPERTYNAME=(GEOM)&srsName=EPSG:2100&maxFeatures=50&startIndex=50
Project:
Priority:
MajorMajor
Reporter:
pavlos tsagkis
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
