Description:
When previewing a layer published with NetCDF reader as raster data source, the user-selected parameter is not being passed to the the overridden AbstractGridCoverage2DReader method “GridCoverage2D read(GeneralParameterValue params)” in newer GeoServer releases.
When editting the layer, the user is able to give a value for the variable NETCDFPARAMETER. The default value, defined in the NetCDFFormat class, should display (currently, “water_temp”) initially. In all GeoServer releases, the user-supplied value is saved correctly to the layer’s coverage.xml file. However, when the read() method is called with GeoServer versions 2.2-beta2 and 2.2-RC1, the default value is passed as a parameter regardless of what value the user has actually given.
For example, if the user supplies the value “salinity” for NETCDFPARAMETER, and the user is running GeoServer version 2.1.4, then the read() method’s parameter will contain the value “salinity.” However, if the user is running either 2.2-beta2 or 2.2-RC1, then the parameter will contain the default value “water_temp.”
Steps to reproduce:
- Go to http://edac-dap3.northerngulfinstitute.org/thredds/ncss/grid/ncom_fukushima_agg/Fukushima_best.ncd/dataset.html to create a NetCDF file with at least variables “salinity” and “water_temp.” I would strongly recommend defining a minimal bounding box and time range to reduce the size of this test file.
- Add geonetcdf-1.0.jar, joda-time-1.5.2.jar, and netcdf-4.2-min.jar to your web container
- Add new store to GeoServer, with NetCDF Reader as a raster data source
- Use the file that you created in Step 1 as URL connection parameter, including path to file
3. Publish layer and set NETCDFPARAMETER to the value “salinity”
4. With debugger active, preview this new layer with OpenLayers
- If using GeoServer version 2.1.4, then the read() method parameter “params” will contain “salinity” at the first index
- If using GeoServer version 2.2-beta2 or 2.2-RC1, then the read() method parameter “params” will contain “water_temp” at the first index, when it should contain “salinity”
Note
With version 2.2-beta2 and 2.2-RC1, the only exception I have found is when the NETCDFPARAMETER field is left completely blank; in this case, the NETCDFPARAMETER index of “params” will contain a NULL value rather than the default value.
Stacktraces:
Using the eclipse debugger and setting a breakpoint at the read() method results in the following stacktrace for GeoServer version 2.1.4 when previewing the layer:
Daemon Thread [http-8080-3] (Suspended (entry into method read in NetCDFReader))
NetCDFReader.read(GeneralParameterValue) line: 104
RenderedImageMapOutputFormat.readBestCoverage(AbstractGridCoverage2DReader, Object, ReferencedEnvelope, Rectangle, Interpolation, Color) line: 1307
RenderedImageMapOutputFormat.directRasterRender(WMSMapContext, int, List<GridCoverage2D>) line: 849
RenderedImageMapOutputFormat.produceMap(WMSMapContext, boolean) line: 329
RenderedImageMapOutputFormat.produceMap(WMSMapContext) line: 250
RenderedImageMapOutputFormat.produceMap(WMSMapContext) line: 125
GetMap.run(GetMapRequest, WMSMapContext) line: 374
GetMap.run(GetMapRequest) line: 107
DefaultWebMapService.getMap(GetMapRequest) line: 353
NativeMethodAccessorImpl.invoke0(Method, Object, Object) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object) line: 25
Method.invoke(Object, Object…) line: 597
AopUtils.invokeJoinpointUsingReflection(Object, Method, Object) line: 310
ReflectiveMethodInvocation.invokeJoinpoint() line: 182
ReflectiveMethodInvocation.proceed() line: 149
CacheSeedingWebMapService.invoke(MethodInvocation) line: 60
CacheSeedingWebMapService.invoke(MethodInvocation) line: 34
ReflectiveMethodInvocation.proceed() line: 171
CachingWebMapService.invoke(MethodInvocation) line: 58
CachingWebMapService.invoke(MethodInvocation) line: 40
RequestObjectLogger.invoke(MethodInvocation) line: 51
JdkDynamicAopProxy.invoke(Object, Method, Object) line: 204
$Proxy35.getMap(GetMapRequest) line: not available
Dispatcher.execute(Request, Operation) line: 630
Dispatcher.handleRequestInternal(HttpServletRequest, HttpServletResponse) line: 234
Dispatcher(AbstractController).handleRequest(HttpServletRequest, HttpServletResponse) line: 153
SimpleControllerHandlerAdapter.handle(HttpServletRequest, HttpServletResponse, Object) line: 48
DispatcherServlet.doDispatch(HttpServletRequest, HttpServletResponse) line: 875
DispatcherServlet.doService(HttpServletRequest, HttpServletResponse) line: 809
DispatcherServlet(FrameworkServlet).processRequest(HttpServletRequest, HttpServletResponse) line: 571
DispatcherServlet(FrameworkServlet).doGet(HttpServletRequest, HttpServletResponse) line: 501
DispatcherServlet(HttpServlet).service(HttpServletRequest, HttpServletResponse) line: 617
DispatcherServlet(HttpServlet).service(ServletRequest, ServletResponse) line: 717
ApplicationFilterChain.internalDoFilter(ServletRequest, ServletResponse) line: 290
ApplicationFilterChain.doFilter(ServletRequest, ServletResponse) line: 206
ThreadLocalsCleanupFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 23
ApplicationFilterChain.internalDoFilter(ServletRequest, ServletResponse) line: 235
SpringDelegatingFilter$Chain.doFilter(ServletRequest, ServletResponse) line: 74
SpringDelegatingFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 45
AdvancedDispatchFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 49
SetCharacterEncodingFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 109
FilterChainProxy$VirtualFilterChain.doFilter(ServletRequest, ServletResponse) line: 394
FilterSecurityInterceptor.invoke(FilterInvocation) line: 109
FilterSecurityInterceptor.doFilter(ServletRequest, ServletResponse, FilterChain) line: 83
FilterChainProxy$VirtualFilterChain.doFilter(ServletRequest, ServletResponse) line: 406
ExceptionTranslationFilter.doFilterHttp(HttpServletRequest, HttpServletResponse, FilterChain) line: 101
ExceptionTranslationFilter(SpringSecurityFilter).doFilter(ServletRequest, ServletResponse, FilterChain) line: 53
AnonymousProcessingFilter.doFilterHttp(HttpServletRequest, HttpServletResponse, FilterChain) line: 105
AnonymousProcessingFilter(SpringSecurityFilter).doFilter(ServletRequest, ServletResponse, FilterChain) line: 53
BasicProcessingFilter.doFilterHttp(HttpServletRequest, HttpServletResponse, FilterChain) line: 174
BasicProcessingFilter(SpringSecurityFilter).doFilter(ServletRequest, ServletResponse, FilterChain) line: 53
HttpSessionContextIntegrationFilter.doFilterHttp(HttpServletRequest, HttpServletResponse, FilterChain) line: 235
HttpSessionContextIntegrationFilter(SpringSecurityFilter).doFilter(ServletRequest, ServletResponse, FilterChain) line: 53
FilterChainProxy.doFilter(ServletRequest, ServletResponse, FilterChain) line: 185
FilterToBeanProxy.doFilter(ServletRequest, ServletResponse, FilterChain) line: 99
LoggingFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 71
ReverseProxyFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 183
GZIPFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 41
SessionDebugFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 46
StandardWrapperValve.invoke(Request, Response) line: 233
StandardContextValve.invoke(Request, Response) line: 191
StandardHostValve.invoke(Request, Response) line: 127
ErrorReportValve.invoke(Request, Response) line: 102
StandardEngineValve.invoke(Request, Response) line: 109
CoyoteAdapter.service(Request, Response) line: 298
Http11Processor.process(Socket) line: 859
Http11Protocol$Http11ConnectionHandler.process(Socket) line: 588
JIoEndpoint$Worker.run() line: 489
Thread.run() line: 662
Using the eclipse debugger and setting a breakpoint at the read() method results in the following stacktrace for GeoServer version 2.2-RC1 when previewing the layer:
Daemon Thread [http-8080-4] (Suspended (entry into method read in NetCDFReader))
RenderedImageMapOutputFormat.readBestCoverage(AbstractGridCoverage2DReader, Object, ReferencedEnvelope, Rectangle, Interpolation, Color) line: 1314
RenderedImageMapOutputFormat.directRasterRender(WMSMapContent, int, List<GridCoverage2D>) line: 855
RenderedImageMapOutputFormat.produceMap(WMSMapContent, boolean) line: 332
RenderedImageMapOutputFormat.produceMap(WMSMapContent) line: 254
RenderedImageMapOutputFormat.produceMap(WMSMapContent) line: 126
GetMap.executeInternal(WMSMapContent, GetMapRequest, GetMapOutputFormat, List<Object>, List<Object>) line: 471
GetMap.run(GetMapRequest, WMSMapContent) line: 208
GetMap.run(GetMapRequest) line: 112
AopUtils.invokeJoinpointUsingReflection(Object, Method, Object) line: 318
ReflectiveMethodInvocation.invokeJoinpoint() line: 183
ReflectiveMethodInvocation.proceed() line: 150
CacheSeedingWebMapService.invoke(MethodInvocation) line: 61
CacheSeedingWebMapService.invoke(MethodInvocation) line: 35
ReflectiveMethodInvocation.proceed() line: 172
CachingWebMapService.invoke(MethodInvocation) line: 60
CachingWebMapService.invoke(MethodInvocation) line: 42
RequestObjectLogger.invoke(MethodInvocation) line: 54
JdkDynamicAopProxy.invoke(Object, Method, Object) line: 202
$Proxy36.getMap(GetMapRequest) line: not available
Dispatcher.execute(Request, Operation) line: 772
Dispatcher.handleRequestInternal(HttpServletRequest, HttpServletResponse) line: 272
DispatcherServlet.doDispatch(HttpServletRequest, HttpServletResponse) line: 923
DispatcherServlet.doService(HttpServletRequest, HttpServletResponse) line: 852
DispatcherServlet(FrameworkServlet).processRequest(HttpServletRequest, HttpServletResponse) line: 882
DispatcherServlet(FrameworkServlet).doGet(HttpServletRequest, HttpServletResponse) line: 778
FilterChainProxy$VirtualFilterChain.doFilter(ServletRequest, ServletResponse) line: 311
GeoServerCompositeFilter$NestedFilterChain.doFilter(ServletRequest, ServletResponse) line: 68
FilterSecurityInterceptor.invoke(FilterInvocation) line: 116
GeoServerCompositeFilter$NestedFilterChain.doFilter(ServletRequest, ServletResponse) line: 72
GeoServerSecurityInterceptorFilter(GeoServerCompositeFilter).doFilter(ServletRequest, ServletResponse, FilterChain) line: 91
FilterChainProxy$VirtualFilterChain.doFilter(ServletRequest, ServletResponse) line: 323
ExceptionTranslationFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 113
GeoServerExceptionTranslationFilter(GeoServerCompositeFilter).doFilter(ServletRequest, ServletResponse, FilterChain) line: 91
GeoServerAnonymousAuthenticationFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 53
BasicAuthenticationFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 150
GeoServerBasicAuthenticationFilter(GeoServerCompositeFilter).doFilter(ServletRequest, ServletResponse, FilterChain) line: 91
GeoServerBasicAuthenticationFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 82
SecurityContextPersistenceFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 87
GeoServerSecurityContextPersistenceFilter(GeoServerCompositeFilter).doFilter(ServletRequest, ServletResponse, FilterChain) line: 91
GeoServerSecurityFilterChainProxy(FilterChainProxy).doFilter(ServletRequest, ServletResponse, FilterChain) line: 173
GeoServerSecurityFilterChainProxy.doFilter(ServletRequest, ServletResponse, FilterChain) line: 97
DelegatingFilterProxy.invokeDelegate(Filter, ServletRequest, ServletResponse, FilterChain) line: 346
DelegatingFilterProxy.doFilter(ServletRequest, ServletResponse, FilterChain) line: 259
