[Geoserver-devel] [jira] (GEOS-5245) Integrated GWC capabilities documents generate awkward file name and type
Mike Pumphrey created BugGEOS-5245
Issue Type:
BugBug
Affects Versions:
2.2.x
Assignee:
Gabriel Roldán
Components:
GWC
Created:
01/Aug/12 6:47 PM
Description:
On the integrated GWC homepage (http://localhost:8080/geoserver/gwc), when I click on the WMS or WMTS caps doc links, I get a request to download a file with the name of “geoserver-dispatch.application”. On Windows that is a reserved file extension, and will not open properly.
It would be nice if the file name could be more descriptive (even wmts.xml would be better) and with an appropriate MIME type.
Environment:
trunk (snapshot as of July 31, 2012), Windows 7
Project:
Priority:
MinorMinor
Reporter:
Mike Pumphrey
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
