[Geoserver-devel] [jira] (GEOS-5249) [Geoserver-users] Geoserver 2.2 rc1 corrupt geotiff/wms output
Terry Rankine created BugGEOS-5249
Issue Type:
BugBug
Affects Versions:
2.2-RC2, 2.2-RC1
Assignee:
Andrea Aime
Components:
WMS
Created:
02/Aug/12 8:04 PM
Description:
Test CASE:
Load a GDA94 Geotiff
Ask for it reprojected via the WMS interface (open layers) to wgs84
Inspect the LACK OF OUTPUT… :o
The Original TIFF:
http://aster.nci.org.au/files/SD52_Quartz_Index.tif
http://aster.nci.org.au/files/SD52_Quartz_Index.tfw
The Services on that TIFF
Reprojected (wgs84) - broken
http://aster.nci.org.au/geoserver/aster/wms?service=WMS&version=1.1.0&request=GetMap&layers=aster:SD52_Quartz_Index&styles=&bbox=125.999524454864,-16.0000724184321,132.00035793349,-11.0942389663187&width=512&height=418&srs=EPSG:4326&format=application/openlayers
Origanal projection: gda94
http://aster.nci.org.au/geoserver/aster/wms?service=WMS&version=1.1.0&request=GetMap&layers=aster:SD52_Quartz_Index&styles=&bbox=125.999524454864,-16.0000724184321,132.00035793349,-11.0942389663187&width=512&height=418&srs=EPSG:4283&format=application/openlayers
An externally reprojected TIFF gda94->wsg84 (same one via the GDAL libs)
http://aster.nci.org.au/geoserver/test/wms?service=WMS&version=1.1.0&request=GetMap&layers=test:test&styles=&bbox=125.9995244548645,-16.00007241843212,132.00035793349002,-11.09423896631874&width=512&height=418&srs=EPSG:4326&format=application/openlayers
Environment:
Linux (Centos)
Sun JVM
Project:
Priority:
MajorMajor
Reporter:
Terry Rankine
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
