[Geoserver-devel] [jira] (GEOS-5250) Adding a layer programmatically causes connection leak problem
Ariel Núñez created BugGEOS-5250
Issue Type:
BugBug
Affects Versions:
2.1.4, 2.1.x
Assignee:
Andrea Aime
Created:
03/Aug/12 11:46 PM
Description:
Adding a layer via the rest api causes an error:
Could not save the layer hti_hazardhydrology_exceptionalflood_westdepartment_nathat_polygon_052010, there was an upload error: java.io.IOException: Schema ‘http://www.openplans.org/topp:hti_hazardhydrology_exceptionalflood_westdepartment_nathat_polygon_052010’ does not exist.
Causing all subsequent layers import to error with:
Error deleting PostGIS table hti_hazardgeology_landslidesdetail_point_022010:table “hti_hazardgeology_landslidesdetail_point_022010” does not exist
CONTEXT: SQL statement “DROP TABLE public.hti_hazardgeology_landslidesdetail_point_022010”
PL/pgSQL function “dropgeometrytable” line 23 at EXECUTE statement
Could not save the layer hti_hazardgeology_landslidesdetail_point_022010, there was an upload error: java.io.IOException: Error occured on rollback
This was originally found with a custom build of 2.1.x using GeoNode extensions and then verified with a vanilla 2.1.4 using gsconfig for the data upload. Full instructions and link to datasets can be found in the relevant GeoNode issue:
https://github.com/GeoNode/geonode/issues/354
Full geoserver logs are available at:
http://ingenieroariel.com/static/geoserver.log
Environment:
Ubuntu 12.04
Project:
Priority:
MajorMajor
Reporter:
Ariel Núñez
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
