Issue Type:
Bug
Affects Versions:
2.1.3
Assignee:
Andrea Aime
Components:
WMS
Created:
13/Aug/12 2:25 PM
Description:
Running into a peculiar issue when trying to add new layers from shapefiles in a directory on the local machine. I’m able to add the shape files and configure through Geoserver without issue, but when I go to preview the layer through open layers preview, I get the following exception:
<?xml version=“1.0” encoding=“UTF-8” standalone=“no”?><!DOCTYPE ServiceExceptionReport SYSTEM “http://192.168.50.59:8085/geoserver-2.1.3/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd”> <ServiceExceptionReport version=“1.1.1” > <ServiceException>
java.lang.NullPointerException null
</ServiceException></ServiceExceptionReport>
When I go back to view the layer’s settings I’m greeted with an error at the top of the page:
See attached image
Additionally when I click on the “Publishing” tab I am present with the following stack trace:
org.apache.wicket.WicketRuntimeException: Exception in rendering component: [MarkupContainer [Component id = kml.regionateAttribute]]
at org.apache.wicket.Component.renderComponent(Component.java:2725)
at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1538)
at org.apache.wicket.Component.render(Component.java:2517)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1440)
at org.apache.wicket.MarkupContainer.renderComponentTagBody(MarkupContainer.java:1603)
at org.apache.wicket.MarkupContainer.renderAssociatedMarkup(MarkupContainer.java:696)
at org.apache.wicket.markup.html.panel.Panel.onComponentTagBody(Panel.java:114)
at org.apache.wicket.Component.renderComponent(Component.java:2686)
at org.apache.wicket.MarkupContainer.onComponentTagBody(MarkupContainer.java:1527)
at org.apache.wicket.markup.html.list.ListView.renderItem(ListView.java:624)
at org.apache.wicket.markup.html.list.ListView.renderChild(ListView.java:612)
at org.apache.wicket.markup.repeater.AbstractRepeater.onRender(AbstractRepeater.java:103)
at org.apache.wicket.markup.html.form.Form.onComponentTagBody(Form.java:1995)
at org.apache.wicket.MarkupContainer.autoAdd(MarkupContainer.java:229)
at org.apache.wicket.markup.resolver.MarkupInheritanceResolver.resolve(MarkupInheritanceResolver.java:66)
at org.apache.wicket.markup.resolver.ComponentResolvers.resolve(ComponentResolvers.java:81)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1444)
at org.apache.wicket.markup.resolver.MarkupInheritanceResolver.resolve(MarkupInheritanceResolver.java:73)
at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1554)
at org.apache.wicket.Page.onRender(Page.java:1575)
at org.apache.wicket.Page.renderPage(Page.java:913)
at org.apache.wicket.protocol.http.WebRequestCycle.redirectTo(WebRequestCycle.java:186)
at org.apache.wicket.request.target.component.PageRequestTarget.respond(PageRequestTarget.java:58)
at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:865)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:579)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1555)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.NullPointerException
at org.geoserver.catalog.impl.DefaultCatalogFacade.getResource(DefaultCatalogFacade.java:288)
at org.geoserver.catalog.impl.CatalogImpl.getResource(CatalogImpl.java:413)
at org.geoserver.catalog.impl.CatalogImpl.getFeatureType(CatalogImpl.java:507)
at org.geoserver.catalog.ResourcePool$FeatureTypeCache.removeLRU(ResourcePool.java:1392)
at org.apache.commons.collections.map.LRUMap.addMapping(LRUMap.java:239)
at org.apache.commons.collections.map.AbstractHashedMap.put(AbstractHashedMap.java:282)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:687)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:599)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureType(FeatureTypeInfoImpl.java:86)
at sun.reflect.GeneratedMethodAccessor271.invoke(Unknown Source)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144)
at $Proxy10.getFeatureType(Unknown Source)
at org.geoserver.wms.web.publish.KMLLayerConfigPanel$AttributeNamesModel.load(KMLLayerConfigPanel.java:63)
at org.apache.wicket.model.LoadableDetachableModel.getObject(LoadableDetachableModel.java:120)
at org.apache.wicket.markup.html.form.AbstractChoice.getChoices(AbstractChoice.java:211)
at org.apache.wicket.markup.html.form.AbstractChoice.onComponentTagBody(AbstractChoice.java:351)
… 149 more
This first happens when I try to configure data using OSM data converted to shape files downloaded from cloudmate. After receiving the error initially with one of these sets of shape files, I tried using another set from provided by a client and same error. I’ve got over 100 layers running on this server mixed between shapefiles and Postgres database and I’m not doing anything different while adding these.
Not exactly sure what’s going on here. Any help you might be able to lend is much appreciated. Also, if you need any other information, please let me know and I will provide.
Thank You.
Environment:
Linux Ubuntu 10.04.3 LTS - Geoserver 2.1.3 - Apache Tomcat 6
Project:
Labels:
exception
Priority:
Major
Reporter:
Fernando Vega
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
