[Geoserver-devel] [jira] (GEOS-5270) SQL Views bounding box parameter
Jonas Reinhardt created ImprovementGEOS-5270
Issue Type:
ImprovementImprovement
Assignee:
Andrea Aime
Created:
14/Aug/12 9:08 AM
Description:
We have data in a table with latitude and longitude values which we present to GeoServer in the form of a view
SELECT id, GeomFromText(concat(‘POINT(’,lng,’ ‘,lat,’)')) as pt
FROM table
We then produce point icons with GeoServer.
The table consist of 100000 points and GeoServer fetches the data over and over again. The time consuming part is the data transfer from database to GeoServer. It would be an improvement to be able to send the bounding box for the SQL View data to be fetched.
Environment:
NA
Project:
Priority:
MinorMinor
Reporter:
Jonas Reinhardt
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
