Andrea Aime created GEOS-5287 |
Issue Type: |
Bug |
Affects Versions: |
2.2-RC2 |
Assignee: |
Components: |
Google Earth KML Output |
Created: |
25/Aug/12 3:36 AM |
Description: |
Running the following link: http://localhost:8080/geoserver/topp/wms/kml?layers=topp:states&mode=superoverlay with the configuration suggested in the release manual testing script (SAMP_POP attribute and external sorting mode) results in GE popping up error windows with documents that failed to parse, here is one example: In fact the above returns an empty document (as in, nothing, squat, not even the kml root elements) and writes out no error to the logs. |
Fix Versions: |
2.2-RC3 |
Project: |
Priority: |
Major |
Reporter: |
