[Geoserver-devel] [jira] (GEOS-5288) When I add a gridset to geowebcache.xml and restart geoserver, I receive the error: cannot construct org.geowebcache.grid.srs as it does not have a no-args constructor
Bernhard Kamps created BugGEOS-5288
Issue Type:
BugBug
Affects Versions:
2.1.4
Assignee:
Andrea Aime
Components:
GWC
Created:
27/Aug/12 8:09 PM
Description:
construct org.geowebcache.grid.SRS as it does not have a no-args constructor
---- Debugging information ----
message : Cannot construct org.geowebcache.grid.SRS as it does not h
cause-exception : com.thoughtworks.xstream.converters.reflection.ObjectAcces
sException
cause-message : Cannot construct org.geowebcache.grid.SRS as it does not h
class : org.geowebcache.config.GeoWebCacheConfiguration
required-type : org.geowebcache.grid.SRS
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshall
er.java:89)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnm
arshaller.java:76)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConv
erter.unmarshallField(AbstractReflectionConverter.java:246)
erter.doUnmarshal(AbstractReflectionConverter.java:218)
erter.unmarshal(AbstractReflectionConverter.java:162)
er.java:82)
arshaller.java:76)
arshaller.java:60)
at com.thoughtworks.xstream.converters.collections.AbstractCollectionCon
verter.readItem(AbstractCollectionConverter.java:71)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.p
opulateCollection(CollectionConverter.java:68)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.u
nmarshal(CollectionConverter.java:61)
er.java:82)
arshaller.java:76)
er.java:82)
arshaller.java:76)
arshaller.java:60)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller
.java:137)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarsh
al(AbstractTreeMarshallingStrategy.java:33)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:923)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:899)
at org.geowebcache.config.XMLConfiguration.loadConfiguration(XMLConfigur
ation.java:395)
ation.java:379)
ation.java:370)
at org.geowebcache.config.XMLConfiguration.initialize(XMLConfiguration.j
ava:853)
at org.geowebcache.layer.TileLayerDispatcher.initialize(TileLayerDispatc
her.java:190)
her.java:165)
at org.geowebcache.layer.TileLayerDispatcher.reInit(TileLayerDispatcher.
java:119)
at org.geowebcache.layer.TileLayerDispatcher.<init>(TileLayerDispatcher.
java:67)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Sou
rce)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:1
00)
… 57 more
Caused by: com.thoughtworks.xstream.converters.reflection.ObjectAccessException:
Cannot construct org.geowebcache.grid.SRS as it does not have a no-args constru
ctor
at com.thoughtworks.xstream.converters.reflection.PureJavaReflectionProv
ider.newInstance(PureJavaReflectionProvider.java:71)
erter.instantiateNewInstance(AbstractReflectionConverter.java:308)
erter.unmarshal(AbstractReflectionConverter.java:161)
er.java:82)
… 92 more
6248 [main] ERROR org.mortbay.log - Nested in org.springframework.beans.factory.
BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL
[jar:file:/C:/Program%20Files/GeoServer%202.1.3/webapps/geoserver/WEB-INF/lib/gw
c-2.1.4.jar!/geowebcache-geoserver-context.xml]: Cannot resolve reference to bea
n ‘gwcTLDispatcher’ while setting constructor argument; nested exception is org.
springframework.beans.factory.BeanCreationException: Error creating bean with na
me ‘gwcTLDispatcher’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.
1.3/webapps/geoserver/WEB-INF/lib/gwc-2.1.4.jar!/geowebcache-core-context.xml]:
Instantiation of bean failed; nested exception is org.springframework.beans.Bean
InstantiationException: Could not instantiate bean class [org.geowebcache.layer.
TileLayerDispatcher]: Constructor threw exception; nested exception is com.thoug
htworks.xstream.converters.ConversionException: Cannot construct org.geowebcache
.grid.SRS as it does not have a no-args constructor : Cannot construct org.geowe
sException
com.thoughtworks.xstream.converters.reflection.ObjectAccessException: Cannot con
er.java:82)
arshaller.java:76)
er.java:82)
arshaller.java:76)
arshaller.java:60)
er.java:82)
arshaller.java:76)
er.java:82)
arshaller.java:76)
arshaller.java:60)
.java:137)
ation.java:395)
ation.java:379)
ation.java:370)
ava:853)
her.java:190)
her.java:165)
java:119)
java:67)
rce)
00)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy
.instantiate(SimpleInstantiationStrategy.java:87)
at org.springframework.beans.factory.support.ConstructorResolver.autowir
eConstructor(ConstructorResolver.java:248)
at org.springframework.beans.factory.support.AbstractAutowireCapableBean
Factory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
Factory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
Factory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
Factory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getOb
ject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistr
y.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBe
an(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean
(AbstractBeanFactory.java:185)
(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver
.resolveReference(BeanDefinitionValueResolver.java:269)
.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolve
ConstructorArguments(ConstructorResolver.java:495)
eConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.
preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finish
BeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationCon
text(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationConte
xt(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitiali
zed(ContextLoaderListener.java:45)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitiali
zed(GeoServerContextLoaderListener.java:18)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.
java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
a:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
dlerCollection.java:156)
39)
.java:152)
39)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
39)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
6264 [main] INFO org.mortbay.log - Opened C:\Program Files\GeoServer 2.1.3\logs
2012_08_28.request.log
6279 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8080
Environment:
Windows 7
Fix Versions:
2.2-RC3
Project:
Priority:
MajorMajor
Reporter:
Bernhard Kamps
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
