Christian Mueller created GEOS-5294 |
Issue Type: |
Bug |
Affects Versions: |
2.3-beta1, 2.2 |
Assignee: |
Components: |
Security |
Created: |
03/Sep/12 2:38 AM |
Description: |
A CAS service ticket is valid only once. The protocol is transparent for the client, the client itself never sees a CAS ticket. If a client (e.g. openlayers) uses CAS to authenticate against stateless (OGC) services, the authentication filter has to create an HTTP session to store the authentication token, otherwise only one geoserver request is possible. |
Project: |
Priority: |
Major |
Reporter: |
