Sergio created GEOS-5297 |
Issue Type: |
Bug |
Affects Versions: |
2.1.3 |
Assignee: |
Attachments: |
cql_flter_ServiceException.log |
Components: |
REST |
Created: |
05/Sep/12 9:29 AM |
Description: |
We have installed Geoserver 2.1.8, Postgres 8.4.1, The problem is that the cql_filter parameter has an special character: As a result Geoserver throws the Exception you can see in the attached file: standard_conforming_string is on in postgres. select * from “limites_municipales” where etiqueta like u&‘Garaf\00EDa’; This issue is similar to the one solved in 4177: How can we get a solution to this problem? Thank you in advance. Kind regards. |
Environment: |
Centos |
Project: |
Labels: |
exception |
Priority: |
Major |
Reporter: |
