[Geoserver-devel] [jira] (GEOS-5300) The GWC setting "Enable direct integration with GeoServer WMS" is not restored after restart
Krister Wicksell created BugGEOS-5300
The GWC setting “Enable direct integration with GeoServer WMS” is not restored after restart
Issue Type:
BugBug
Affects Versions:
2.2-RC3
Assignee:
Andrea Aime
Components:
GWC
Created:
07/Sep/12 2:03 AM
Description:
After enabling direct integration with GWC via the web interface the setting will be activated and works but when I restart GeoServer direct integration of GWC will be disabled again.
A workaround is to enable the setting in the file gwc-gs.xml under <directWMSIntegrationEnabled>.
Environment:
Windows 7
Project:
Priority:
MinorMinor
Reporter:
Krister Wicksell
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
