[Geoserver-devel] [jira] (GEOS-5305) GetFeatureInfo WMS not work with geoserver-2.1.4-arcsde-plugin.zip on Geoserver 2.1.4
Richard de Bruin created BugGEOS-5305
Issue Type:
BugBug
Affects Versions:
2.1.4
Assignee:
Andrea Aime
Components:
WMS
Created:
12/Sep/12 8:14 AM
Description:
We are install a new server with Geoserver 2.1.4. The data coming from a old server running 2.1.1. Everything worked well except in the layer preview the identify (getfeatureinfo) is not working. No result is returned. Also not if you fire the request in the webrowser. The workaround we use now is using the old ArcSDE plugin (version 2.1.1), and then everything works. So it looks like there is some bug in the ArcSDE plugin of version 2.1.4.
Environment:
Windows 2008R2, Tomcat 6.0.18, SDE 9.2 (latest servicepack) and Oracle 10
Project:
Priority:
MajorMajor
Reporter:
Richard de Bruin
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
