[Geoserver-devel] [jira] (GEOS-5312) CSV WFS output format doesn't deal with Windows newlines
Robert Coup created BugGEOS-5312
CSV WFS output format doesn’t deal with Windows newlines
Issue Type:
BugBug
Affects Versions:
2.1.x, 2.2.x
Assignee:
Andrea Aime
Components:
WFS
Created:
16/Sep/12 9:46 PM
Description:
The CSV WFS format correctly deals with embedded unix newlines (\n) in attribute data, which ensures the field is enclosed in double-quotes.
FID,geom,label,number\r\n
fid--79854fbd_139d1dd3621_-7fa7,POINT (5 4),"A long label\nwith newlines",2\r\n
When the attribute contains Windows-style newlines, the output is not quoted, which then then splits the record across two lines.
fid--79854fbd_139d1dd3621_-7fa7,POINT (5 4),A long label\r\nwith newlines,2\r\n
Pull request to follow.
Environment:
Linux
Project:
Priority:
MajorMajor
Reporter:
Robert Coup
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
