Henrik Berggren created GEOS-5338 |
Issue Type: |
Bug |
Affects Versions: |
2.2 |
Assignee: |
Components: |
WMS |
Created: |
05/Oct/12 5:16 PM |
Description: |
When I try to use the function IEEERemainder with geoserver 2.2 it always complains with : “ERROR [geotools.rendering] - Filter Function problem for function IEEEremainder argument #1 - expected type double” Even though that the argument is of type double. It works find with geoserver 2.1.1 on the same server with the same datasource (Postgis). |
Environment: |
Linux Ubuntu 12.04 LTS, Java™ SE Runtime Environment (build 1.6.0_26-b03) |
Project: |
Priority: |
Major |
Reporter: |
