Olivier LEPRETRE created GEOS-5340 |
Issue Type: |
Bug |
Affects Versions: |
2.2 |
Assignee: |
Components: |
SQLServer |
Created: |
09/Oct/12 6:53 AM |
Description: |
Hi, I try to use MS SQL Server but it doesn’t show up in the datastore list I set I started and restarted geoserver, pc, no way, I never see SQL SERVER in the datastore page. I saw thru the web that I’m not alone in this case. Could that be a bug ? Thanks, Olivier |
Environment: |
Windows 7 / X64, JRE 6 |
Project: |
Priority: |
Major |
Reporter: |
