[Geoserver-devel] [jira] (GEOS-5350) Build failures in wps-core on master and 2.2.x
Ben Caradoc-Davies created BugGEOS-5350
Issue Type:
BugBug
Affects Versions:
2.3-beta1, 2.2.1
Assignee:
Andrea Aime
Components:
WPS
Created:
15/Oct/12 1:07 AM
Description:
Consistent wps-core failures in Hudson, Jenkins, local Maven, and Eclipse.
Failed tests:   testIncompatibleGridCoverages(org.geoserver.wps.gs.BinaryProcessingsTest)
  testStyle(org.geoserver.wps.gs.StyleCoverageTest): expected:<[attachment; filename=result.tiff]> but was:<[inline; filename=execute.xml]>
  testStore(org.geoserver.wps.gs.StoreCoverageTest)
  testStatisticsTazDem(org.geoserver.wps.gs.RasterZonalStatsTest): expected:<[14400]> but was:<[]>
  testStatisticsSfDem(org.geoserver.wps.gs.RasterZonalStatsTest): expected:<[424]> but was:<[]>
Tests in error:
  testStatisticsTazDem(org.geoserver.wps.gs.RasterAsPointCollectionTest): java.util.HashMap cannot be cast to net.opengis.wfs.FeatureCollectionType
  testAddOperation(org.geoserver.wps.gs.BinaryProcessingsTest): Unable to parse the header for the provided input
  testMultiplyOperation(org.geoserver.wps.gs.BinaryProcessingsTest): Unable to parse the header for the provided input
  testScale(org.geoserver.wps.gs.ScaleCoverageTest): Unable to parse the header for the provided input
  testCrop(org.geoserver.wps.gs.CropCoverageTest): Unable to parse the header for the provided input
  testRangeLookup(org.geoserver.wps.gs.RangeLookupTest): Unable to parse the header for the provided input
Tests run: 128, Failures: 5, Errors: 6, Skipped: 0
Project:
Priority:
BlockerBlocker
Reporter:
Ben Caradoc-Davies
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
