[Geoserver-devel] [jira] (GEOS-5361) Layer publishing tab exception when all non-default styles deleted
Andrwe Ayers created BugGEOS-5361
Issue Type:
BugBug
Affects Versions:
2.2
Assignee:
Andrea Aime
Components:
UI
Created:
19/Oct/12 1:03 PM
Description:
We had a layer with a valid default style and a valid “other” style. The “other” style was deleted, but not explicitly removed from the layers list of style. After that we could no longer view the Publishing tab for the layer. The exception below would be displayed. The layer.xml file is as follows:
<layer>
<name>transmission_line_platts</name>
<id>LayerInfoImpl–466c8ad9:138335b43c3:-7e7e</id>
<type>VECTOR</type>
<defaultStyle>
<id>StyleInfoImpl–466c8ad9:138335b43c3:-7e80</id>
</defaultStyle>
<styles class=“linked-hash-set”>
<style/>
</styles>
<resource class=“featureType”>
<id>FeatureTypeInfoImpl–466c8ad9:138335b43c3:-7e7f</id>
</resource>
<enabled>true</enabled>
<advertised>true</advertised>
<queryable>true</queryable>
<attribution>
<logoWidth>0</logoWidth>
<logoHeight>0</logoHeight>
</attribution>
</layer>
If I manually delete the <styles> node, reload GeoServer’s config configuration, I can then view the publishing tab.
Here’s the exception:
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [MarkupContainer [Component id = extraStyles]] at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1765) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.extensions.markup.html.form.palette.Palette.onBeforeRender(Palette.java:191) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:151) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.extensions.markup.html.tabs.TabbedPanel.onBeforeRender(TabbedPanel.java:244) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.markup.html.form.Form.onBeforeRender(Form.java:2056) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Page.onBeforeRender(Page.java:1531) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.Component.prepareForRender(Component.java:2292) at org.apache.wicket.Page.prepareForRender(Page.java:1521) at org.apache.wicket.Component.prepareForRender(Component.java:2329) at org.apache.wicket.Page.renderPage(Page.java:892) at org.apache.wicket.protocol.http.WebRequestCycle.redirectTo(WebRequestCycle.java:186) at org.apache.wicket.request.target.component.PageRequestTarget.respond(PageRequestTarget.java:58) at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105) at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160) at javax.servlet.http.HttpServlet.service(HttpServlet.java:727) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882) at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789) at javax.servlet.http.HttpServlet.service(HttpServlet.java:727) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173) at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:97) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206) at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152) at org.mortbay.jetty.Server.handle(Server.java:324) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505) at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380) at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395) at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.NullPointerException at org.geoserver.wms.web.publish.StyleNameRenderer.getIdValue(StyleNameRenderer.java:21) at org.apache.wicket.extensions.markup.html.form.palette.component.Recorder.initIds(Recorder.java:116) at org.apache.wicket.extensions.markup.html.form.palette.component.Recorder.onBeforeRender(Recorder.java:87) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) … 126 more
Project:
Priority:
MajorMajor
Reporter:
Andrwe Ayers
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
