[Geoserver-devel] [jira] (GEOS-5366) Better heuristic for OWS Request filenames
David Winslow created ImprovementGEOS-5366
Issue Type:
ImprovementImprovement
Assignee:
Andrea Aime
Created:
23/Oct/12 4:48 PM
Description:
The org.geoserver.ows.Response class has a default definition of getAttachmentFileName() that uses the MIME type of the response to guess a filename to use in the Content-Disposition header. Currently the heuristic used is to take the part of the MIME type up to the first / character. Instead, I think it should be everything between the first / and the first ; if any. This is because MIME types are structured as a general category (application, text, imageā€¦) and a specific subtype - the subtype more often corresponds to a commonly used file extension than the general category. Examples:
  • text/css
  • text/xml
  • image/png
  • image/jpeg
etc.
Project:
Priority:
MajorMajor
Reporter:
David Winslow
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
