[Geoserver-devel] [jira] (GEOS-5384) WPSException - can't set exceptionCode and locator value
Mark Lague created BugGEOS-5384
WPSException - can’t set exceptionCode and locator value
Issue Type:
BugBug
Affects Versions:
2.2-RC3
Assignee:
Andrea Aime
Components:
WPS
Created:
30/Oct/12 1:46 PM
Description:
I created a new WPS process with some validation methods.
package ca.gc.nrcan.egp;
import java.util.ArrayList;
import java.util.Arrays;
import java.util.List;
import java.util.logging.Logger;
import javax.mail.internet.AddressException;
import javax.mail.internet.InternetAddress;
import org.geoserver.wps.WPSException;
import org.geoserver.wps.gs.GeoServerProcess;
import org.geotools.geometry.jts.JTSFactoryFinder;
import org.geotools.process.ProcessException;
import org.geotools.process.factory.DescribeParameter;
import org.geotools.process.factory.DescribeProcess;
import org.geotools.process.factory.DescribeResult;
import com.vividsolutions.jts.geom.GeometryFactory;
import com.vividsolutions.jts.geom.Polygon;
import com.vividsolutions.jts.io.ParseException;
import com.vividsolutions.jts.io.WKTReader;
@DescribeProcess(title="VectorExtractionWPS", description="Extraction service for vector data")
public class VectorExtractionWPS implements GeoServerProcess {
	private static Logger log = Logger.getLogger(VectorExtractionWPS.class.getName());
   @DescribeResult(name="result", description="output result")
   public String execute(
		   @DescribeParameter(name="layers", description="name of the layers to clip") String layers,
   		   @DescribeParameter(name="outputFormat", description="output format of the spatial dataset") String outputFormat,
   		   @DescribeParameter(name="delineation", description="outline used for clipping") String delineation,
   		   @DescribeParameter(name="email", description="email address") String email)
		   validateEmail(email);
		   validateWKT(delineation);
		   validateLayers(layers);
		   validateOutputFormat(outputFormat);
	   return SubmitToLSF.BSUBvector(layers, outputFormat, delineation, email);
   	static void validateWKT(String wkt) {
	   Double maxArea = new Double(50.00);
		GeometryFactory geoFac = JTSFactoryFinder.getGeometryFactory(null);
		WKTReader reader = new WKTReader(geoFac);
		try {
			Polygon polygon = (Polygon) reader.read(wkt);
			if (polygon.isEmpty()) {
				throw new WPSException("empty polygon", "InvalidParameterValue", "delineation");
			if (!polygon.isValid()) {
				throw new WPSException("invalid polygon", "InvalidParameterValue", "delineation");
			}else {
				Double area = polygon.getArea();
				if (area > maxArea) {
				throw new WPSException("polygon to big", "InvalidParameterValue", "delineation");
		}catch (ParseException e) {
			log.info("validationWKT exception : " + e.getMessage());
	static void validateEmail(String email) {
		try {
			InternetAddress emailAddr = new InternetAddress(email);
			emailAddr.validate();
		}catch(AddressException e) {
			log.info("validateEmail exception : " + e.getMessage());
			throw new WPSException(e.getMessage(), "InvalidParameterValue", "email");
	static void validateLayers(String layers) {
		ArrayList<String> layerList = new ArrayList<String>(Arrays.asList("bs", "en", "fo", "hd", "ic", "la", "li", "lx", "ss", "to", "tr", "ve"));
		List<String> layerError = new ArrayList<String>();
		String[] ll = layers.split(",");
		for (int i = 0; i < ll.length; i += 1) {
			if (!layerList.contains(ll[i].toLowerCase())) {
				layerError.add(ll[i]);
		throw new WPSException("invalid layer(s)", "InvalidParameterValue", layerError.toString());
	static void validateOutputFormat(String outputFormat) {
		ArrayList<String> formatList = new ArrayList<String>(Arrays.asList("geodatabase_file", "shape", "geojson", "gml2"));
		if (!formatList.contains(outputFormat.toLowerCase())) {
			log.info("validateOutputFormat exception : invalid output format " );
			throw new WPSException("invalid output format", "InvalidParameterValue", outputFormat);
The validation methods throw a WPSException when there’s an invalid parameter. I’m setting the exceptionCode and locator value on the WPSException, but when I call the service with any type of error I always receive this message (the only thing that changes is the text in ows:ExceptionText which is always doubled!):
<wps:ExecuteResponse xml:lang="en" service="WPS" serviceInstance="http://localhost:8080/geoserver/ows?" version="1.0.0">
    <wps:Process wps:processVersion="1.0.0">
        <ows:Identifier>gs:VectorExtractionWPS</ows:Identifier>
        <ows:Title>VectorExtractionWPS</ows:Title>
        <ows:Abstract>Extraction service for vector data</ows:Abstract>
    </wps:Process>
    <wps:Status creationTime="2012-10-30T15:35:54.335Z">
        <wps:ProcessFailed>
            <ows:ExceptionReport version="1.1.0">
                <ows:Exception exceptionCode="NoApplicableCode">
                    <ows:ExceptionText>Process failed during execution org.geoserver.wps.WPSException: Invalid email address Invalid email address</ows:ExceptionText>
                </ows:Exception>
            </ows:ExceptionReport>
        </wps:ProcessFailed>
    </wps:Status>
</wps:ExecuteResponse>
Is this a bug or am I missing something in my code?
Thanks for any help,
Mark
Environment:
war package deployed in Tomcat server 7.0 on a Windows XP OS
Project:
Priority:
MinorMinor
Reporter:
Mark Lague
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
